im trying to take out the dash in my 85 to swap it to the 92. i got the dash free and the bulkhead removed and most of the other wiring but i noticed its stuck on the speedo cable. does anyone know how to get the speedo cable free? id hate to cut it but if i have to then i will
speedo cable removal
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
00 Tahoe Z71........Stock
97 K1500 lt4 cam, 1.6s, MPFI, Solid axled, IROKs,------winter beater -
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
there should be a clip that you need to push up to release the cable from the speedo
From TGO:
There is a black retaining clip holding the speedo cable to the cluster. It is diamond shaped. Just push that clip towards the cluster and hold it. The speedo cable should pull right out the back.
Post Whore
- 3000
- Tyler Porter
- student
cant figure it out
i cut the cable, the thing is stuck on there. something else is holding the dash up. Mike mentioned it shouldnt be the power windows and locks just yet so something else is still catching. also my cluster will not come forwardLast edited by TylerT/AZ28; August 6th, 2012, 11:14 PM.91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
