brake light
  • brake light
    i know im an idiot. okay now that thats outta the way, how do you change a brake light bulb on a 86 camaro? i have black out lens's which i dont think hinder anything but im not taking them off cause they wont go back on easily.
    Take off the back panel in the INTERIOR and you will see large plastic wing nuts. Remove those the light will fall out.
      open the t-top compartment... inside you will find a bunch of wingnuts to the back of the tail lights if not the bulbs themself... if wingnuts just unscrew them the whole light pops out in one piece and you replace the bulbs from the back... if its got the back of the bulbs you just push in the plastic clip and turn it then pull back...
        wasnt sure if it was the same as mine been a while sence i messed with a maro..
          got it
          k i just did the interior and went smooth was just so ADD about getting it off i didnt relize to go from there the bulb was good just bad connection it fixed tho, put in a new bulb just in case...
