When low beams are on the high beams are glowing very slightly, switch problem??
High beam problem
Yup, that's what I said in the shoutbox. Need to find all the harness ground locations and check 'em. I had something very similar happen and I had a ground wire that wasn't hooked up. On my 4th gen, it was right behind the passenger side headlight bucket and bolted right next to the radiator support.- Brian Meissen
