Hello fellow mifbody users, I am looking for some good engine building shops in metro Detroit. I live in the Bloomfield area and I am looking to get some work done on my 92Z28. I have some extra money so I want to first get the engine rebuilt, while the engine is being rebult I want to add some performance upgrades. (Heads, Cam, Intake, Runners, Headers, Stall, Shift Kit, Etc). Does anyone know some good shops in Southeast Michigan that they would reccomend? Preferably a shop that they have been to or have known about for a while. Thanks in advance.
Best Shops in Metro Detroit
You looking for a shop to just rebuild the motor, or to pull it and do the whole job?When in doubt, Whip it out !
Diversified in Brighton...owner retired from GM (LSX R&D develepment team), recently had a published LS conversion in a 3rd gen in Hot Rod Mag....owner is now the newly appointed Director of Operations for Lingenfelter...AND they are doing the install for my project! Need a number?sigpic
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
State motor rebuild they are on Gratiot around 11 mile. We had Brians done there, we took the block and crank in had it bored and new pistons and rings and crank turned and new bearing. He assembled the short block cost $1100. We had another guy mill and do mild porting and replace valve springs and seals on heads. We furnished new springs ect. that was $400.00. We then assembled the engine and installed it. Just to give you some ideas.sigpic
Expense is relative I guess. I considered his quote reasonable considering the work required, reputation and compentacy. Best thing to do is call and discuss the scope of work.Originally posted by d2harris View PostThanks OVRKILL for your response, yes please PM me the number. Are they expensive?
Diversified Creations
Mike Copeland (owner)
810-227-4777sigpic
Lurker
- March 13th, 2010
- 3476
- TJ
- 1995 Chevy Camaro Z28
- Clinton Twp Michigan
- Powerline Tree Trimmer.
My whole thing is build it not bought it. If you don't know how to build and engine now is the time to learn.Originally posted by Yoshi94Mines about an inch bigger than Kyles. I need to get one of thosesigpicOriginally posted by ryanwarby01Put it this way, if you have a money tree a LT1 is a wood chipper!
It doesnt make much sense to buy a dipping tank and your own machining, balancing, and measuring equipment for one engine build. Thats a great attitude if you have someone elses equipment to borrow.Originally posted by Fox Slaughter View PostMy whole thing is build it not bought it. If you don't know how to build and engine now is the time to learn.-Joel
