Factory foglights (Which way do they go?)
  • Factory foglights (Which way do they go?)
    HI Guys,
    I was wondering if you can help me with my fogs.
    When I bought my car last year, new factory foglights came with the car, however they were not installed. I put them on, but I'm not sure if I put them in right.
    The lense is thicker on one side and then tapers to the other side of the fog.
    I installed them so that the thicker part is toward the center of the car. I hope that makes since to you. Does this sound right ?
    I just wanted to make sure they are installed correctly. I don't want to look like a dufus.
    Thanks,
    Brian
    2013 Stage II Nickey Camaro Convertible #10
    Special Edition
    Red Magnuson Super Charger w/a rear cog drive, ZL-1 fuel pump, Nickey cnc ported heads, Nickey spec. custom grind cam, Roto Fab CAI, Kooks LT's, No Weeds dual mode elec. diverters, Pedders eXtreme XA Coilovers, Pfadt ZL Spec sway bars, 20" AR Torq Thrusts wheels w/ polished billet Nickey centers, Nickey pistol grip shifter, upgraded 1400hp rear axles, 800hp @ the crank, 670RWHP w/613ft. lbs. of torque @11 lbs. boost! Check out album for pics!
    You installed them CORRECTLY Brian.
      Thanks for quick reply Gary!
      I was hopin I wouldn't have to change them.
      Brian
      Special Edition
        No Problem Brian.
          HI BRIAN,
          "OL Time Rock n' Roller on Board "
            Hi Dennis,
            Special Edition
              Originally posted by Bowtie-Bri
              HI Guys,
              Thanks,
              Brian
              You will know if they are backwards because it makes the car look cross-eyed!
