Originally posted by Kwazrollinz28
View Post
305 to 400 small block
Yea totally agreed. I do agree that and LS1 would prob be better on gas and everything but a 400 or bored out 400 would still be nice. I would love to build a mean 350,355,383 or 400
Not sure where your looking, 4 grand will get you and entire longblock and a complete trans and wiring harness. There was a guy selling two truck shortblocks on MM a few weeks ago, one for $600 the other for $400.Doing less with more
http://motownmuscle.com/forums/showt...-1998-corvette
He says he will sell the engine and trans for 2K, although the trans won't be useful to you I'm sure he'd part with just the motor for a good price.
http://motownmuscle.com/forums/showt...ght=shortblock
here are those shortblocks I mentioned above.Doing less with more
check this out
http://www.carcraft.com/techarticles...ild/index.html
If I had knew about this about a year ago...
Do they build engines for that cheap or is that just how to build an engine that cheap?Originally posted by 86Camaro View Postcheck this out
cant figure out how to use the dang website.
Obsessed
- January 13th, 2006
- 593
- C
- It's a big pretty white plane, with wheelz, curtains in the windows and it looks like a big tylenol
- MI
- Engineer
Really??Originally posted by DETROITMUSCLE View Post5.3 LS motor can be build for $1500 easily.
$889 for the stock Master Rebuild Kit
$150 For Refurbing the Heads
$1000 in machinework to get it back to what it needs to be.... (Bore, Hone, Resurface, install cam bearings)
If it can all be done for $1500, please let me know what machine shop you are going to.
Even though the 400s ate cam bearings and had cooling issues... I still think it would be cheaper to go carb'd old school.
I really like the LS engine and its capabilities...but when your on a tight budget...I don't think it can be done. At least not equal to an old school engine. Sure there are deals to be found, as I found my motor for fairly cheap. It's getting it to run correctly with your setup where the chunk of change comes into play.Last edited by TrickyTransAm; October 10th, 2010, 12:26 PM.
Well I was searching the other day for motors and came across this 388 out of a mud bogger for 1000$. I dont think thats to bad. Just gotta talk my dad into getting it
I agree with this 100%...Originally posted by TrickyTransAm View PostI still think it would be cheaper to go carb'd old school.
I really like the LS engine and its capabilities...but when your on a tight budget...I don't think it can be done. At least not equal to an old school engine. Sure there are deals to be found, as I found my motor for fairly cheap. It's getting it to run correctly with your setup where the chunk of change comes into play.Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
Stock 350 with a vortech = 300 hp to the wheel.Originally posted by RcamaroS View PostYea totally agreed. I do agree that and LS1 would prob be better on gas and everything but a 400 or bored out 400 would still be nice. I would love to build a mean 350,355,383 or 400
Just rolling with the dog pound..
I was thinking more of a 350 h/c/i and maybe some spray (125 shot) down the road.
I seen Levi's 350 and im pretty interested in that one because I heard alot of people like the 355 and itll be a pretty sweet car with a 355
If i did a 406 swap do you think my 700r4 would be capable of that power or should i swap it to a TH400 or 4l60e? If i did a different trans would i have to change the drive shaft? And how much gas mileage do you think i would get with a 3.42 rear end in the city without raggin on it?
