I want to get rear posi on my 86 305 TPI. Can anyone help me out? I dontreally know anything about it.
Posi
I'm not sure you would want full on posi... a locking diff like a detroit or eaton locker, or maybe a limited slip diff.. would probably be better..
BTW.. Love the car... only seen a handful of blue Irocs..
2001 Bright Rally Red Camaro SS - M6, Livernois Stage 3 ported 243 heads, Livernois 230/236 114 LSA cam, FRPP 36# injectors, Ported TB, SLP MAF, Volant CAI, Kooks 1 3/4 headers & ORY, GMMG Cat-back. Koni SA 4/3's, BMR springs, Founders Performance, STB, LCA's and Panhard bar.
Positraction ,twin grip,gov lock, trac-loc and many others are simply the brand names that companies have chosen to describe their limited slip differentials.
a locker is not desirable for a street car due to the noise they make.
the new WAVE TRAc is probably the best ever built but are expensive and not made for many axles.
a spool completely locks the two drive axles together and is only recommended for certain applications
Don't know where you are in Michigan, but give DTS in Warren a call. They did the rear on my car and their prices were better than others I called and the work was second to none.When in doubt, Whip it out !
from what iv learned posi is when both tires spin. also iv heard the stock rear end in these cars are to weak for a full or mini spool and you will break axle shafts. but i could be wrong.Originally posted by Bluedevil19 View PostThanks Guys! I love that blue also for some reason to me blue cars always look really cool. But anyways all posi is really is limited slip?92 Chevy Camaro RS 25th anniversary-dream car-stock-slow-needs work
86 VW Golf GTi-SOLD
81 Chevy Silverado-355-to much to list-old man style-hoping for 12s
"Positraction" is just the GM trademark for "limited slip"...and the "spool" will replace the rear end if that's how you wanted to go...and if you go to a spool, guaranteed you'll be replacing axle shafts...personally not what I would recommend unless you're 600+ hp and it's a drag-only car...Originally posted by FER92RS View Postfrom what iv learned posi is when both tires spin. also iv heard the stock rear end in these cars are to weak for a full or mini spool and you will break axle shafts. but i could be wrong.Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
Spools are good for straight-line racing. Both wheels turn at the same speed (there's also welding the spider gears, but let's not make this complicated). Posi or limited slip spins both wheels, but allows the outside rear wheel to spin faster when cornering, either with cones or friction discs. When Jeff says "drag only" he means straight-line, no turns. Up until one or both the axles give up, there will be a lot of tire squealing when turning. Honestly though, I'd worry about that almost last. From the sounds of it, you're looking to build the power in the plant at the moment. Switching out the carrier (in which case, you might as well go bigger gearing) is not going to be very cheap.Originally posted by 81DaytonaPaceCar View Post"Positraction" is just the GM trademark for "limited slip"...and the "spool" will replace the rear end if that's how you wanted to go...and if you go to a spool, guaranteed you'll be replacing axle shafts...personally not what I would recommend unless you're 600+ hp and it's a drag-only car...Last edited by steddy; October 22nd, 2010, 01:15 AM.sigpic
cheap way is look on craigslist or call some local junk yards looking for a 93-02 trans am or Z28 year end from a Manual car this way you get the 3.42 LSD can be had for less than 300 most times and you can just toss it in. as far as "welding the spider gears" it only works in a pinch not something that will remain permanent and at that point youve toasted the Diffie. and it will need to be replaced. I have a spool in my 9" carrier it definately isnt Street friendly04 dodge ram HemiGtx 001/433
08 yamaha R6 (fuel saver)
i have a mini spool in my truck. my rear end is built to handle it though. also my truck is a drag truck not a dd.
i heard manual irocs came with lsd. is this true?92 Chevy Camaro RS 25th anniversary-dream car-stock-slow-needs work
86 VW Golf GTi-SOLD
