I have a 1986 Iroc-z with the 305 TPI engine, It seem to be idling way to high. Around 1500 RPM does anyone know how i can adjust the idle? I apprecieate any responses! And thanks!
Adjust Idle
Check for vacuum leaks and leaks in/on the intake. spray starting fluid at the vacuum lines, intake, etc and if the idle raises even more you've found your leak.2005 Yamaha R6
