Formula phase II
  • Formula phase II
    for those that saw the bird this past summer, i thought you might like to get an idea of what you'll see next year...
    PRO-CRUZ IROC
    1987 IROC-Z 305 TPI 5 Speed
    IROC pics http://s276.photobucket.com/albums/kk29/slo-hand/
    IROC and the bird projects http://www.cardomain.com/id/Slohand
    nice.... whats the specs on the motor
      Sweet!
        Awesome Tim!!!
          nice work tim
          West Michigan Firebird Club
          www.wmfirebird.com
            Nice work, Tim.
              thx, if looks could kill, it would be a winner, but actually it is a real nice cruzer.
              it is:
              phase #1 was
              stock 350 block
              LT1 flattop rotating assembly (appx 10.5 to 1)
              comp 408-8 cam (short duration/hi lift for an awesome bottom end)
              52 mm throttle body
              reworked/upgraded 700R w/shift kit
              2400 stall
              phase #2 adds:
              afr 180 heads
              holley stealth ram intake/fuel rails
              mega squirt ECU
              1.6 full roller rockers/comp pushrods
              hedmann long tubes/custom Y pipe
              custon subframe connectors (plans from 3rd gen org)
              the heads and intake should move the hp/torque curves up a bit. it had too much bottom and was lacking a bit in the upper rpm range with the TPI and stock heads.
              and before spring, it is getting a dana 60 rear end (3.55 or 3.73 gears)
              derek did a sideways straight stunt during a cruz last fall, and hurt the stock rear end, it has a nice harmonic vibration to it now.
              the only issue still facing us is hood clearance, but cutting reinforements should give us enough.
              PRO-CRUZ IROC
                WOW!
                That looks killer
                I'll have to come and check her out
                  Thing looks sick!!! I would vote for 3:73's if we were voting
                  burn rubber!
                    with ample low end torque, i am thinking 3.55 will be plenty...
                    the heads are on and torqued down... working on opening up the headers to match the gaskets and heads
                    PRO-CRUZ IROC
                      WOW! That looks stunning.
                        Good work bud!
                        How's that heater doing for ya?
                          you know you are welcome here any time you want Kyle... and the heater is working out just fine.... so i guess i better see ya soon and get it paid for
                          PRO-CRUZ IROC
                            Call me some time
                            Or I'll call you
                              It sure looks impressive! Now we just have to see a video of it running.
