serpetine setup questions
  • serpetine setup questions
    I am trying to find info I ran across in one of the forums about what you need to swap a serpetine setup on a non serpentine car.
    Any help would be great..
    99 Buick Regal GS- New DD
    SOLD-1967 Buick Skylark
    I know you need to change the water pump because of the rotation. Sorry I couldn't be more help.
      serp is the way to go. are you an air car...smog? i pulled everything when i pulled the entire motor. but basically all you need is the crank pully water pump pully, tensioner, i'm not sure on all camaro's water pump running back wards. so i just bought a new one from and 88 up camaro. they make smog delete pullys, and a/c delete pullys try summit way cheaper then gmpartsdirect ebay is an option. there are the two mamoth aluinum brackets that bolt to the front of the motor....to make things easier i would try and find an 88+ fbody and pull everything from there. note power steering pump. you'll need a puller and a pusher to change that pully and its kinda a PITA...the end result it much nicer, it really cleans up the motor. i hated the v-belt setup.
        yes Car Craft just covered this recently and I found the article after I posted this.. thanks though for the post, I will post it up when I get everything and put on..
