1991 Z28 Camaro
    Rubasteve thats gonna cost you a good......7 grand........hmm i wonder who else did that?
      Well, its certainly not going to be cheap, but the suspension work will cost an ass load too. The comment about TPIs not reaching 400hp, check out thirdgen.org if you haven't, 400hp on a N/A TPI engine isn't exactly unheard of, but I do agree with you, the rear end will have to be replaced, and the T-5 is gonna go.
      \"Chevy boys, we like it fast
      So I drop it at the low, heavy at the gas
      Before you know it, we be haulin\' ass
      about 145 on the digital dash\"
        That rearend will hold up if you build it right. Its certainly a lot cheaper than a 9 inch or a 12 bolt. I myself have gone the route of new axles and i'll be pushing a little over 400 at the wheels. I guess we'll see how that goes.
          ive been on the forums @ TGO for about 3 or 4 years now...and as for making a 400hp TPI motor yes, it can be done... I guess...but the only thing that can make that much power would be with cubic inches, most likely a 427ci stroker or bigger, and even then your going to be choking the hell out of the motor. TPI was designed for a 230 horsepower 305, not a thing bigger.
          Change the intake or switch to a carb, its that simple.
            89 Kicker, you are correct sir. I got my car back, and It won't breathe past 5000rpms. How difficult would it be to change it over to carb? How much can I get a better injection system for?
              520 bucks for a holley stealth ram Accel super rams are around 700ish the miniram is a bit more than that.
                Shawn, what is, if any, difference between the 3 performance wise? Or quality wise?
                  Nice lookin car Steve, love the way it sounds with the cam.
                    Tell ya the truth its a preference thing. They all seem to perform about the same, each has something that it excels in. The stealth ram is by far the best bang for the buck though. The mini ram is basically an LT1 intake made by TPIS and the Accel Super Ram is a Tpi looking setup with shorter runners and a larger plenum.
                      intake
                      i like the edelbrock rpm air gap good from idle to around 7,000 or if you can find a old holley contender like i picked up idle to 7,200 never is gaging for air and with a newer street avenger or even a nice holley performer you will notice the difference but then you get into haveing to keep the carb tuned in and you loose gas millage pretty bad.. but its the cheep way out i got the contender off my friend for like 50 bucks and ive seen them on ebay for around 75. and just got a new 770 street avenger best holley carb i ever owned not to touchy like the old ones.
                        your the first person I've heard like holleys new carbs, everyone on nastyz28 has them rebuilt within a month, then throws them away after 6 and gets a good carb
                          holley carb
                          this is the first time i ever got a good holley carb maybe i lucked out on it... havent had to re tune it at all... must have been a glitch at holley...lol
                            if you want to buy a carb or intake new I can probably get a good deal through my dad's supplier. I got all my autometer phantoms gauges and pod for 300 bucks new. Just let me know the part number and I can look it up for a price.
                            5th gen Camaro V6 Forums
                            http://www.bowtiev6.com
                              Sounds good 97RS4Life, I will have to do some research and see which one is the best for my set up, as well as reviews on each.
                                not a problem, let me know
