how to pull my front clip ??????
  • how to pull my front clip ??????
    can anyone tell me how to pull the whole front clip off my 91 rs i want to pull the fenders and bumper as one i just have never done this before thanks
    1. Disconnect the negative battery cable.
    2. Remove the air cleaner assembly, as required.
    3. Remove bumper filler panel.
    4. Remove the fascia center bracket at the front end panel reinforcement.
    5. Disconnect all electrical equipment, such as headlamps, turn signals, horns, fog lamps, etc.
    6. Raise and safely support the vehicle.
    7. Remove the front bumper fascia extension.
    8. Remove the bolts from the bumper impact bar and radiator lower air baffle, if equipped.
    9. Remove the push-on retainers attaching the bumper fascia to the bumper impact bar.
    10. Lower the vehicle and remove the bolts attaching the outer brackets to the front end inner structure.
    11. With the aid of an assistant, remove the fascia carefully as not to scratch or damage the assembly.
    To install:
    1. With the aid of an assistant, install the fascia carefully as not to scratch or damage the assembly.
    2. Raise and safely support the vehicle.
    3. Install the bolts attaching the outer brackets to the front end inner structure. Torque the bolts to 84 inch lbs. (9.5 Nm).
    4. Install the push-on retainers attaching the bumper fascia to the bumper impact bar.
    5. Install the bolts at the bumper impact bar and radiator lower air baffle, if equipped.
    6. Install the front bumper fascia extension.
    7. Connect all electrical equipment, such as headlamps, turn signals, horns, fog lamps, etc.
    8. Install the fascia center bracket at the front end panel reinforcement.
    9. Install bumper filler panel.
    10. Install the air cleaner assembly, as required.
    11. Connect the negative battery cable.
      For the fenders, sorry no pic...
      2. Remove the hood.
      3. Raise and safely support the vehicle.
      4. Remove the lower fender bolts and inner wheel house panel.
      5. Remove the rocker panel molding.
      6. Remove the lower front end panel deflector-to-fender bolts.
      7. Remove the bolt from the support brace.
      8. Remove the front end bumper fascia-to-fender nuts and screws.
      9. Remove the hood hinge-to-fender bolts.
      10. Disconnect all electrical connections from horn, turn signal lamps, etc.
      11. Remove the fender by sliding rearward and outward, at rear, with the aid of an assistant. Place an old blanket over the fender as to avoid scratches or dents.
      To install:
      1. Install the fender with the aid of an assistant. Place an old blanket over the fender as to avoid scratches or dents.
      2. Connect all electrical connections to the horn, turn signal lamps, etc.
      3. Install the hood hinge-to-fender bolts.
      4. Install the front end bumper fascia-to-fender nuts and screws.
      5. Install the bolt at the support brace.
      6. Install the lower front end panel deflector-to-fender bolts.
      7. Install the rocker panel molding.
      8. Install the lower fender bolts and inner wheel house panel.
      9. Install the hood.
      10. Disconnect the negative battery cable. Align the fender and hood as necessary, placing existing shims in original positions.
        I have done this twice with 2 different Camaro's
        There are 4 bolts on each sides, plus 2 on the F/X.
        and you have to pull the push ins as well (I think that is what they are called). also two nuts on the top in the middle by the hood latch, and 2 on each side of the lights. That pretty much covers what I did, but both my cars were carb'd,
        Good luck! and take pics
        Here are the pics of my 2 swaps.
        www.londontransam.com
        www.hawk-design.com
          ooops sorry I didnt see that you wanted fenders back.
          Again, good luck and please show us some pics of your progress.
          www.hawk-design.com
            It's not that difficult at all...just takes time. The only difficult part is getting the headlight bar/bracket assy out of the front facia if you choose to tear it down that far. Getting the top nuts off the facia to fender interface can be a little of a challenge too unless you have micro sized hands.
              thanks you guys for the help and i guess im gonna have to have someone with micro sized hands help me cause im not that small
