Ok since everyone was so much help on the last one..... i have a set of fourth gen rims and after much unnecessary work i have got them on my third gen... anyway thats not the question.... looking for a good set of rubber to throw on the 8" wide wheels.. any suggestions?
Tires?
are you looking for a good street tire or something you can use at the track as well? also how much you wanna spend2011 Ford Raptor SuperCrew
What offset are you running now? And do you still have the factory rear end?Originally posted by FstZ28HO View PostOk since everyone was so much help on the last one..... i have a set of fourth gen rims and after much unnecessary work i have got them on my third gen... anyway thats not the question.... looking for a good set of rubber to throw on the 8" wide wheels.. any suggestions?
You run out of space very quickly with third gens...the rims may fit, but the tires may rub...
And something else you may want to consider...the departure angle going rearward on the body was not really developed for a super wide tire...in a rear view, if the above assumptions are correct, it could look like the tire and rim are completely sticking out of the wheelwell.
If that is not a concern (or it may even be the desired result), you can run a spacer on the rear, but you'll likely have to replace the lugs with longer ones to get that to work.Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
more like finishing a minitub in the back. I didnt want the tires sticking out a mile and looking retarded... I was gonna run just some wheel spacer but im sure the edge of the tire would have been right on the wheel well. i currently have 225/50/zr16 on the car i dont really know what im looking for something aggressive.... i have 2 sets of tires... and price doesnt matter... i found out if you wanna do it right sometimes it take a little more money.
aka "Plum Nuts"
- June 4th, 2008
- 5699
- Larry Meissen
- Macomb, Michigan
- Realtor
This is what a 245/50/zr16 looks like with a zero offset wheel...I think you'll already be further outboard than this...look at how much tire is exposed down low at the ground effects panel...this appearance will just get larger...Originally posted by FstZ28HO View Postmore like finishing a minitub in the back. I didnt want the tires sticking out a mile and looking retarded... I was gonna run just some wheel spacer but im sure the edge of the tire would have been right on the wheel well. i currently have 225/50/zr16 on the car i dont really know what im looking for something aggressive....
EDIT: I forgot to add that the front track in 3rd gens is about 10 mm wider than the rear track, which can create some appearance problems.
When I redid the wheels, in a plan view the rear tire is actually tucked inside of the o/b edge of the wheel well lip by 5 mm...the front are line to line in a PV...I almost went with a 255 tire, and that would have put me line to line in the rear, but the fronts would stick OUT of the wheel well by 5 mm.
That, and a 245 front WILL rub at a full turn lock with a zero offset wheel...not bad, but a 255 would be worse.
Not at all what I wanted...and I didn't want to run different size tires.
I'd double check your offset to be sure where you sit before making a decision.Last edited by 81DaytonaPaceCar; April 7th, 2009, 03:58 PM.Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
