auto trunk latch not working need help 1991 firebird
i just opened my trunk and and now it wont retract when i close it. ive tried taping on the motor and checked my fuses but i dont know what else to do. need to fix fast. it wont close all the way.
PLEASE HELP ME!!!!!
HISTORY OF CARS PAST AND PRESANT (none of them were wrecked)
1989 S10 standard with 350 carb'd, th350, shift kit, shorties, 600cfm, hooker TD's, 3.23 non posi, B&M shifter(sold)
1991 firebird with t-tops and 3.1L, 700r4, 3.23 non posi, flowmaster cat back, 15ibs injectors, (sold)
1991 formula with t-tops, WS6, 5.0TPI, WC T5. 3.42 posi. magnaflow cat back, 52mm TB, and hurst billet (sold)
1994 camaro z28 with t-tops, 5.7LT1, T56, 3.42 posi. CAI, elbow, Airfoil, SFC, STB, pro 5.0, flowmaster cat back. (sold)
2000 Trans am with t-tops, 5.7LS1, T56, 3.42posi, LT'S, ORY, magnaflow, lid, lingenfelter intake, 3pt SFC, STB, LCA, (current)
Is the motor working? Obviously it did when you opened it but if you hit the switch again can you hear it working? Or the motor went bad is all I can think off if you checked the fuses and they were good...I just had to replace mine last month!
I can't remember how I fixed my pull-down motor...
What I think it was is the motor got "stuck", and you have to cycle it down and back up.
I think theres a switch on the motor somewhere (a manual button or something).
EDIT: Found it
You opened the hatch before it had completed the "down" cycle. You need to have it finish the down cycle or it won't come back up. Here's how you re-set it. Look at the latch with a flashlight. There is a black switch attached in front of the latch by a single hex-head screw. There are three wired coming out of it (orange, black and white). On the opposite side of the switch from the screw is a small black paddle. That is the actual switch part of the switch. Press on that paddle and the motor should turn on and power the latch down. You'll hear a CLICK which is the reversing switch being tripped to stop the down cycle. Release the switch and the motor will turn on again in reverse direction and power the latch portion all the way up. Again it will end with a CLICk of the reversing switch shutting down the up cycle. That's it your unit is now re-set and ready to pull down once you've closed the hatch.
Press the hatch release and listen for the relay click (two people here would be helpful). It it's not clicking, you either have a bad relay, or your not getting power. Considering it sounds like it worked before, I'd lean towards the former.
If it does click, the striker could be bad...
