T-Top Bar Leaks :(
  • T-Top Bar Leaks :(
    Well I pealed back the weatherstripping at the t-top bar to see why water was comming in around my headliner and I found Rust... The front of the t-top bar is rusting out at least at the front. The rust isn't bad, I am hoping I can fill it with something.
    Just replace the bar (what I mentioned in the shoutbox).
    http://www.mifbody.com/vbulletin/sho...ighlight=T-Top
      So Whats under that T-Top Bar?, The interier metal headliner structure right?
        Yeah
          They all leak...it's a third gen. I've gotten mine down to a very minimal leak now, but they still will leak under a hard rain like we had down in Indy or at the Berger show. It's the one bad thing about my car I cannot not change.....if I could it would be a hardtop.
            Yeah, but a rotted out t-bar will make it RAIN in the car...
              My new (1992) car is a t-top and I have been dreading reading post's like this one
                Jake, do you see the bolt holes I'm talking about?
                  yup.
                    They all leak...it's a third gen.....
                    Mine don't leak.
                    Only time it has ever leadked is if you hit the top of the side glass with high pressure water.
                      Gary, have you replaced the weatherstripping?
                        Nope Original 1987 weatherstripping.
                          Wow, you are truly lucky there. Then again, I believe my weatherstripping was original on my car - except the center bar was rusted...found that out when I replaced the probably-fine weatherstripping...
                            I had a third gen and mine leaked also, as a matter of fact the leak rotted the car away. Never will i own a t-top car again.
                              wow tough crowd. mine only leak when i do a thurow washing. and it only get a couple drips down the inside windows.
                              although ive only driven it in the rain/ mist twice? not meaning too.
                              still common people.
