What to do while the motor is out?
    That looks like a decent kit, but with a good set of heads you are going to be looking at 400 hp or more like Jeff said, I wouldn't be comfortable with that cast steel crank over 400 personally, yeah, its probably rated to 500, but why push it.
    If it were me, and I don't know what your budget is but this is going to cost money either way, I'd be looking at this:
    http://store.summitracing.com/partde...rsview=sku&Ns=
    Now the only drawback to that kit is the Hypereutectic pistons instead of forged, but they might allow you to swap them. Although Hypereutectic are fine for NA applications up to 500 hp I'd say. Its more the cylinder pressures that can hurt them, when you start adding boost or nitrous and increasing the cylinder pressure you can hurt them after a certain point.
    Just my suggestion, Well, there, I spent more of your money, lol.
      He has nice heads:
      http://www.worldcastings.com/prods_p...portsmanii.htm
      Did you get 64 or 72 cc heads??
      That will make a difference in compression also.
      Can you give us all the specs of the cam shaft you have now?
      Lift, Duration @ .050, Lobe Center Line, Intake Center Line.
        toss the motor in the trash..
        Hamster Wheel Hamster Wheel HAMSTER WHEEL!!!!!!!
        -Im Ron Burgundy?
          Personally, I would never destroke a 400, it's a waste of money in my book. Destroked 400's came into existance for one reason, to meet a rules regulation on maximum cubic inchs allowed. If you are going to alter the cubic inches of a 400....stroke it. But I'd just leave it alone personally. My 406 had torque out the ass and was a blast to drive on the street. Being able to smoke off a tire at 30mph was intimidating.
          Oh and....smack your buddy and let him foot the bill for "knowing what he was doing".
            lol , i second that
            - - 5.3/4L80e/T7875 - -
            - Huron Speed Turbo Kit -
            1998 Formula
              Originally posted by Formula Z View Post
              lol , i second that
                yea whats done is done, he is a close friend i would never have in pay for that... and he couldn't even if i did want him to lol. in the end its my fault i should have done something that important myself never had someone else do it. all i can do now is chalk this one up as a lesson learned.
                  here are the cam specs phantom
                  cam specs--int ech
                  adv dur: 274 286
                  Dur @ .050: 230 236
                  valve lift: 490 490
                  lobe sep: 110.0
                    thats not a big cam by any means.. Did the valve hit on every piston?
                      no just 1, 7, 4, and 8
                      here is a link to the specs of my cam for more info if you need it
                      http://www.compcams.com/Cam_Specs/Ca...x?csid=87&sb=2
                        could have been degreed wrong
                        Sold!
                        www.fquick.com/lozanoa11
                        94 Grand Cherokee (sold)
                        95 Accord(for sale)
                        99 Outback (snow destroyer)
                          I'm about 100% sure it had to do with valve lash then.. How did he lash the valves? Thats just as important as putting oil in the pan....
                            yea we came to the conclusion that he didnt set the valve lash right he didnt really know what he was doing... but its to late now.
                              Live and learn.. now you've got a chance to do it right, make it faster, and a helluva lot more reliable. If ya have any questions.. theres plenty of guys to help you out.. If you need tech on things you can check out www.thirdgen.org as well.
                                thanks as we can see i need help lol so im taking advice and input from anyone that KNOWS what their doing this time lol
