Alright well two weeks ago I started picking up parts for my 84 camaro I got world sportsman 2 heads, a comp cams cam and lifters, and a new intake.
Along with all the gaskets and such to go with it.
I had a friend set the valve lash (said he had done it b4 and knew what he was doing) so we get her all back togather he sets the roller rockers we are good to go. Not so much we crank her over and nothing and pops through the carb. So we take the valve covers off to watch the roller rockers valves and such and notice one roller rocker is complelty off the spring. Turns out we bent 3 pushrods 4 vavles and nicked 4 pistons.
Now i have to pull the motor and replace all that so my question to you guys is what should I do while its out? I have extra money and would like to do a nice streetable build from the ground up. The car is not my DD and wont even be driven everyday of the summer with gas the way it is. Any suggestions are apprciated. I'v never done a full build like this so Im not sure were to start.
The block is a 1972 4 bolt main 400ci sbc std bore right now, the only parts I absolutely want to keep are the heads. which like I said are world sportsman II's. The other new parts like the cam and lifters and intake if I have to change I will
