Head light motor relay/fuse?
  • Head light motor relay/fuse?
    Ok so I bought a set of Fiero head light motors. (Thanks again Wade) I put the 1 on after having to mod part of it and now I can lower and raise my head light manually. So next I need to figure out where the relay is. I looked under the front end and traced the wire. From the motor it goes to a yellow box then a couple inches later goes to a black box. Is the yellow box a inline fuse? and the black box the relay?
    No idea on the relay, but what did you have to mod to make it work?
    Wade
      The part that attaches to the little bar that moves the head light up and down was different. So just had to remove the nut, swap them then retighten the bolt. The old motor came off easy, then 1 I got from you I had to use a little persuasion to get it off.
        I tried to remove that when I pulled it apart but it didn't want to come off and I thought it might be the same for the Firebird so I left it on.
        Wade
          What is it with these pop-up head lights ,anyway.
          Friggin' G.M. can't figure out how to make them last ...
          A BUNCH of $hit ,if you ask me !!!!
          **** FEAR THIS ! ***
            That's part of why the C6 Vettes don't have them!
            Wade
              They send a man to the Moon ,but they can't figure out a Pop-Up head light......................F igure that !!
