what the heck is my problem??
  • what the heck is my problem??
    Ok.. I need to figure out this problem and fix it... Quick.
    Ok when i start off and accelerate quickly.. or attempt to... the car will try and die... RPMS drop way down and it sounds like it dies but then picks up.
    Attempting at a burnout the car died as soon as i tried spinning the tires... restart get them spinning again and can barely get over 1500 rpms and it dies again... put it in reverse and it dies all the time...
    Right now the only way i can really drive is i have to manually shift the car and its an automatic... start off in first rev it high then slide up to second... any ideas or places i should check into?...
    I've been told the TPS but i replaced it and it still does it.
    1989 Chevrolet Camaro- Currently in pieces...
    Maybe a fuel problem?
      Fuel pump and filter have both been replaced.. did it before and after i replaced them... I ran fuel system cleaner through it... nothing.
        O2 sensor? Vacuum leak? And have you changed or checked your plugs, plug wires, or your ignition?
        Boosted AND all wheel drive.
          plugs and wires yes... my dad had told me the ignition was fine... He apparently checked it .... as for vaccuum leak i dont know were to beging.. i know the drivers side EGr is like no there... but i dont know whats missing from it and what not... if anyone has detailed pictures of that... that would be cool.
            Is it carburated or tpi?
              if u had a vaccum leak it prolly would not idle very well, jump up and down ect..
              sometimes you an hear it too
              you'd be suprised how easyily a hose can become dry rotted and cracked
              The LS1 or Go Home Crew
              ASE master certified
                And check your carb or throttle body. It sounds like a fuel delivery problem to me
                  pull those plugs too and check em
                    Yeah. They might have been fouled out. Or they might have to much carbon built up on them
                      Its a TBI.
                      it idles but it will bounce a bit.. only about 200 rpms though.. Tonight graduation and i have to spend all day tomarrow with a blow torch but tuesday im going to sit down and see if i cant find my problem.
