murfy's law
  • murfy's law
    i dont know why but for the last year or so i have been in a tight grip of murfy's law and i think it grabed my car to because i can not get a single thing to work in my car. some examples
    1.cant get those brand new gauges to work only the volts gauge works the rest just blow the fuse no matter what size the fuze.
    2.wipers just blow the fuze
    3.radio gets so hot it wil acually burn your hand everything is wired right my brother in law checked and he is a electrician.
    4.cant get an engine to work int the car right.
    5.i cant seem to get a transmission in the car right ethier.
    6.and the last time i pushed the car out of the garage the passenger rear floor board broke in half and it's not rusty at all.
    those are just a few things that are going rong.
    and i am in 4-h and i bought bull that we were going to make into a steer to raise for the fair and it got out of the pin when it was still a bull in mid hunting season and we just got a chance to put it down about 2 weeks ago. i would say i am cursed or something
    Damn man, Murphy has a firm grip on you... Hopefully things will work themselves out and you can get the car squared away soon!! Good luck brother!!
      thank you. i still have hopes for the meet & greet
        :X2:
        Maybe an exorcism...an offering to the gods...something...
          can you perform an exorcism...an offering to the gods...something because with my luck i would screw it up or it wouldnt work
            thats prolly a result of a mis wiring on your part, you shouldn't be sticking larger fuses in because a smaller one blows
            The LS1 or Go Home Crew
            ASE master certified
              OH PLEASE DEAR LORD DO NOT USE BIGGER FUSES THEN WHATS RATED!!!!!
              sorry I just personally don't like pulling dashes apart to replace all/some of the factory harness because someone smoked up the wiring. if it blows with whats rated something isn't right... period.
              have you done a car fax on your car? sounds like its been an accident perhaps, maybe a pinched/damaged harness. just a thought. but anyways if your lucky and you haven't already caused damaged then take it somewhere that does electrical repair, a place similar to where i work. all those symptoms scream fire..
              99 Grand Prix GT - Winter Ride
              ___M&R Electronics ___
              .MECP & ASE Certified.
                Maybe if you spelled my last name right, its Murphy, i can get them to release the death grip on you
                  sorry about the name. and i cant afford to have someone fix my wiring i have to babysit for my money. and i followed those directions for the gauges and only the volt gauge worked and thats not the one i need. i had the dash pad off and everything looks good.
