if you are crusing when it comes on it probaly isn't opening ill try to find the code.
edit: it just says egr system failure. check any lines going to it or wires. clean it out mabey
EGR kicks on at cruising speeds and light accel. Basically allows exhaust gases into the cylinders to cool them down, to prevent NOx emissions. It will not hinder performance of the vehicle unless it sticks open.
personally i dont want exhaust going back threw my nice clean intake
sigpic The LS1 or Go Home Crew
ASE master certified 1998 Camarbo z28-going back to stock 11.3@121 old heads & cam setup
