guages
  • guages
    alright i have a a pillar guage pod and need to figure out what other guage to put in the empty hole.. right now i already have a oil pressure guage and collant temp guage in a pod i made under the center vent in the dash.. and i know i need to put a trans temp in the a pillar pod.. but what other guage should i put in the empty hole>?
    im either leaning towards a nitrous pressure guage (since i plan on doing a small kit on the car this year) or just making a new pod for the center and moving the water temp guage over there and leaving trhe oil pressure in the center
    I have oil temp in mine.
      I plan on getting a digital speedo for my pillar.
        the other thing i have is a digital tach with a shift light. $$$ but worth it IMO.
          i suppose i could do a shift light since i always shift my anyways since i havn't changed the weights and springs yet in this trans.. i suppose that wouldnt; be a bad idea
            Oil temp hands down!!!! This is one of the most important guages to have period!!
              problem would be i would have to pull my oil pan to tap it...unless i did it on the drain plug but then its extremly close to the ground
                yea i like my oil temp gauge. It tells you when youre running your car hard so you know when to lay off... unlike water temp.
                  thats a good point... ill prolly end up with a oil temp guage to fill that spot... now i just need to find that hole you were talking about to put the sender in
                    Sean, there is a pressure port right above the oil fliter boss on the block....you can use that.
                      anbd thank you james... i thought there was a few ports down there..
                        thats the same one i was referring to. I think its about 6" above the oil filter if you have a vertical mount next to the oil pan.
                          next time i get the car out of the barn ill take a look.. which may be this weekend
                            wideband... most important guage ever! it tells you if our rich or lean! i suggest the AEM UEGO, its simple to use and easy to install!
                              speaking of Donnie are they available for my car or just fuel injected?
