L98 Engine Question
  • L98 Engine Question
    This is what Wikipedia states...
    L98
    For the new Generation IV V8, see GM L98. Years: 1985-1992
    The new 1985 L98 added tuned-port fuel injection "TPI", which produced 230 hp (172 kW) and 330 ft·lbf (447 N·m). It was standard on all 1985-1991 Corvettes (rated at 230-250 hp and 330-350ft·lbf torque). Optional on 87-92 Chevrolet Camaro & Pontiac Firebird models (rated at 225-245 hp and 330-345ft·lbf torque) 1987 versions had 10 hp (7.5 kW) and 15 ft·lbf (20 N·m) more thanks to 9.5:1 compression. Compression was up again in 1991 to 10:1 but output stayed the same.
    [edit] L98
    For the tuned-port Generation I engine of the same RPO, see Chevrolet L98 The L98 is a slightly modified version of the L76, devoid of some redundant hardware relating to displacement on demand. Power increased to 362 hp (270 kW) at 5700 rpm and 391 ft·lbf (530 Nm) at 4400 rpm.
    Applications:I understand that some of these cars do not exist, but I was wondering if there is a modern car using an L98 block, or if there is any stock cars with interchangeable parts with an L98 third gen car?
    Those cars are real, they are found in the middle east and other international locations.
    the L98 is a current GenIV engine too ( think its a truck iron block engine) but its nothing at all the L98 in third gens (which would be a GenI sbc)
    GM just reuses engine names, for example there was a LT1 in 1970 and another LT1 in 1992
    Basically there was
    '96 Camaro RS - project
    '97 Silverado Z71 - DD
    '89 Suzuki GSXF 750
      Ahhhh Okay. Its like that LT1 and LT-1 thing. Too bad.
        I wasn't aware that GM brought back the L98...humm, good info!
