Has anyone done the "redneck" method, I am going to go that route i decided, it just is too much work to drop the whole rear end for that thing. Is there a walk through on it anywhere? Pics?
Replacing fuel pump
I would really recommend doing it the RIGHT way.Western Michigan Camaro Club ~ President
I have neither the time, or money to do it, or get it done that way. A guuy said 40 bucks to do it, no way it would be done right. I might as well do it myself so i know that i didnt mess up anything else.
I did the trap door method and its the shit, I can remove my pump in about 15 minutes or less and you'd never know it was there. I'm not sure if the dimensions are the same though.Doing less with more
why waste time when you can do it quick and much easier, who cares if I cut the car I honestly don't plan on selling it anyhow. Besides its weight reduction
Its no different than cutting the front of your car for a intercooler or putting a cage in the car.Doing less with more
Originally posted by DETROITMUSCLE View Postwhy waste time when you can do it quick and much easier, who cares if I cut the car I honestly don't plan on selling it anyhow. Besides its weight reduction
Aman you are soooooooooooooooooo right ihave a nice trap door set up it takes 10 mins .. if you do it the so called right way then you have to cut your exhuast and basicly go threw hours of pure hell ..........v6 to ls1 conversion........Done
2.73 Gears ....................Done
Ram air hood..................Done
Slp lid ..........................Done
Tranny rebuild with shift kit .....Done
Loud mouth ...................Done
YOU CAN'T DO THE TRAP DOOR WITH A THIRD GEN!!!!
It'd have to be a very large hole or you will have to cut hard fuel lines too.
I just put a new pump in my 89 T/A and the hard fuel lines run from the middle of the tank to the driver's side where they meet the chassis.Last edited by scholtmj; September 27th, 2007, 11:14 PM.
- March 29th, 2006
- 1080
- Eric H
- 1997, Pontiac, Trans Am
- Middleville, MI
- Chemical Tech.
I'm changing my pump out Friday morning with a Racetronix kit I just purchased. The previous owner cut the trap door for me, and put a really nice piece of sheet metal over the hole. Hopefully I won't run into any problems, if I do you won't see me at the GVSU car show.
