Can you turn your key "back" on your 2nd Gen? So you can have the radio on. Mine won't turn back. Are they not able to turn back on these old cars? Or is something wrong with mine?
2nd Gen Ignition Question
InActive Member
- December 1st, 2005
- 1208
- Jeremy
- 1978 Pontiac Firebird Formula
- Dorr, Michigan
- Fence Installer
Holley 650cfm Double Pumper
Edelbrock Performer-Plus Cam
Tags: None
Yep, it should turn back.Originally posted by MrMojoRisin681 View PostCan you turn your key "back" on your 2nd Gen? So you can have the radio on. Mine won't turn back. Are they not able to turn back on these old cars? Or is something wrong with mine?
Standard GM issue of the day.
Try moving the steering wheel slightly back and forth and see if it's just a wheel alignment deal.Originally posted by Redd8407I WANT NOISE! SPEED! AN ENGINE THAT SHAKES MY INTERNAL ORGANS LIKE THEY GOT PARKINSON'S! I DONT WANT AN ENGINE THAT IS PARTIALLY POWERED BY MY LAPTOP BATTERY!Originally posted by Z28ISGR8WHY THE F*CK IS THERE A GOAT ON A FERRARI?Originally posted by DarrenI think it is because I take it in and out all the time, the rubber has just stretched out, especially at the bottom where it is really thin. It annoys me more then anything.
