Does it make a difference if the 1971 fiberglass formula hood is attached to standard hinges or the lightweight version? Will either work?
71 formula hood hnges
they will both work the light weight one may flex a little may have to lightin the spring ten. i have a real ram air hood for a 71 firebird forsale i have a 71 trans am and i got it with the car
Post Whore
- November 8th, 2009
- 3000
- Tyler Porter
- 85 Z28, 91 Trans am
- Clinton Township Michigan
- student
the springs on my 79 were firm and i had a fiberglass hood i just took the spring out and got the struts from a ford crown vic that were free from shop class and mounted them. no flex, it stayed open and opened easily91 Trans am, 305, Lt1 cam, 24lb injectors, headers, SLP LM2, SW chassis, massive panhard, lowered, modded TPI, Tuned, 4.10s, Lincoln locked
00 Tahoe Z71........Stock
