Not starting
  • Not starting
    My friends 70's camaro gas cap is locked and it doesn't start...any ideas?
    out of gas
      out of gas
      Clever.... and makes sense. The pump vacuumed the tank so the cap won't release? Must not be a vented tank?
        Good description April!
        Dead Battery?
        Is fuel getting to the carb?
          way to many unknowns, you have to give more info. How in the world can he not get the gas cap off?!
            I have no idea, that was all the information he gave to me... i will find out more now!
            battery is fine- he says
            they can't get the gas cap off to even add more fuel...
              Does it run when gas is poured into the carb? Locking gas caps are usually pretty easy to break loose with some big channel lock pliers..
                does it have an actual lock on the gas cap, most any key or a knife shoved in there will breka the lock, they tend to be pretty cheaply made in my experience.
                00 Tahoe Z71........Stock
                  is he turning the gas cap counter clockwise? but i agree with fred. sounds like its vacume locked if its a non vented tank
                    they haven't tried putting gas on the carb... and i asked him about the gas cap but haven't heard back...
                      It's out of gas, lol
                        Drill a hole in the bottom of the tank and see if any gas comes out
                          so he finally wrote me back and said that there was key to be used on the gas cap but it was lost... what do you guys do with this?
                            find a key of the same kind and it should trick it, it has with all mine, otherwise a knife works to break the tumblers, or a locksmith. nut all in all you should take that cap off and buy a different one afterwards
                              A big pair of channel locks will usually get the cap off. I kept some on hand when I worked at a gas station and people would loose their gas cap key.
