ls1 swap wiring harness
  • ls1 swap wiring harness
    i have been reading that in order to swap a ls1 into another non-lsx vehicle you need to modify the wiring harness.
    why?
    if you have a complete donor car, couldnt you just swap everything over to get it running? no need to ac, cruise, etc
    '96 Camaro RS - project
    '97 Silverado Z71 - DD
    '89 Suzuki GSXF 750
    you may throw codes if some stuff is disconnected?
    Sold!
    www.fquick.com/lozanoa11
    94 Grand Cherokee (sold)
    95 Accord(for sale)
    99 Outback (snow destroyer)
      dont care about codes as long as it runs good. i throw codes as-is anyways (!EGR, !cats)
      '89 Suzuki GSXF 750
        you should be fine
        The LS1 or Go Home Crew
        ASE master certified
          thats what i thought.
          only things im not sure about is gauges & igntion cylinder. i could re-use the key easy but i wouldnt want 4th gen gauges
          '89 Suzuki GSXF 750
            what are you putting it in
              it would be a 2nd gen
              '89 Suzuki GSXF 750
                might have VATS issues
                  cant VATS be deleted with a PCM tune?
                  '89 Suzuki GSXF 750
