Ok I was replacing my horn fuse, so I decided to take a look at all of them..and found in the ign fuse..its labled #15 on the chart I think? So I look at the fuse and its #30 or 35..so I took it out and put in a #15..so I tried to start the car and it wouldnt..but I thought your only suppose to put the correct number in or it could fry or something?
Why is the #30 something working and the 15 wouldnt?..Is it suppose to be like that
That would imply some other problem than the fuse. If the fuse wasn't powerful enough, it would fry it. It could be possible that when switching the fuses something else shorted out? Basically if it was a problem with the fuse being too small it would fry.
1995 Trans Am Firebird. LT1 with 6 Speed manual. cc503 Cam. Pacesetter long tubes with true dual exhaust. LPE CAI. K&N. 4.10 Gears. ZR1 Replica Rims. Comp Cams 1.6 Roller Rockers. Double roller timing chain. BMR Sub Frame connectors. LT4 Knock Mod. Madz28 tune. Pro 5.0 shifter. LS1 Driveshaft. MSD Coil. Sequential Taillights. Custom Interior. Lead foot. CarDomain
Time Slip: 1/4 -- 12.49 @ 116 MPH
