front runners
  • front runners
    Well today I bought front runners from this guy that had a 87 camaro I have a 2002 ta ws6 the guy said they fit on his brothers 98 ta that wasnt a ws6. but anyways I went to go mount them and they didnt fit the caliper was hiting the rim and the studs didnt even go through the holes so I took them back and he was stunned just asmuch as I was they were draglites by weld. but my ? is this is it because its the ws6 package that they wont fit and if it is could you tell me the right size to buy so I can order them this week thanks
    Joe
    you have to grind the calipers, use spacers and longer studs for all Weld wheels on 4th gens
    heres mine
      most use 15x3.5 1.75bs 5x4.75 for drag use only
      15x8 5.5bs rear or
      15x10 7.5 bs
        does any other company make them so I dont have to grind them?
          and they fit on his brothers trans am that was 1998 but it wasnt a ws6
            the brakes are the same on firebirds,ta's and ws6's
            bogart makes some that fit but they are like 900 bucks
              these fit my car fine with no grinding. They are my buddy's but I don't know what they are called and they are not made anymore
              the 16 inch XP's fit but they are not made anymore either
                sometimes they will fit with a 5/16 spacer without grinding.
                look on ls1tech for more info
                  i think the CenterLine Convo Pro's fit with out grinding, however they stick out, and look rather un attractive.
                  the guy was probably just bullshittin ya, for any 4th gen you have to do what larry showed, ARP wheel studs and grind your calipers, or get some nice strange or aerospace brakes
                  1998 Camaro SS Bullseye Turbo
                    it appears that the jegs sports stars fit without spacers or grinding in the front. They are a litttle heavy though
                      yeah I think I'm gonna buy them back lol and get the 5/16 wheel spacer and 3.25'' studs and if that doest work out comes the grinding wheel but also I have another ? can you put 315/35r/17 on the stock 17'' ws6 rims I went to discount order my street slick and the guy said it cant be done.
                        315 can be mounted but are UNSAFE
                        don't do it.
                        get a 275 et street radial if your gonna run the stock size wheel for drag racing
                          yeah I order the 275 bfg for the street and I am gonna get draglite for the rear with a drag slick on it soon but thanks for the info I'll let you know if the spacer worked or not
                            the front runners are 15x4 wiil they still work
                              they should. most use a 5/16 spacer which is not needed with those they should be pretty much in the same spot as a 15x3.5
