I have such bad luck :(
  • I have such bad luck :(
    i think i spun a rod bearing in the SS ive been babying it except for ther ocational quick rev. car has 89 miles on it and its pulling like a 8 count knock, and pulling mad timing. the valve trais is chattering but it needs to be re adjusted, but my oil pressure is fine but my low oil light is on, but i check it and its full, the knocking isnt there all the time, and its real faint, and it only comes in at 3 k. if the car revs past 3k and i idle down it drops below 900 and sometimes stalls, the down rev seems like its alot faster like something is restricting it, it has been running real rich too but i think thats the tune. im just so frustrated, i cant win
    geez sorry to hear that man
      if you spun a rod bearing you would lose oil pressure, you have another issue. Bearings create the oil pressure. You may have another issue but definetly sounds like a short block problem.
        dang that sucks man
        Originally posted by 02hawk796
        3.4 Camaro > < 4.6 Stang
          i lost some oilpressure but when i give it some throttle it shoots up to 40lb. its not in the red roughly 15lb of oil pressure, so it could be the loose valvetrain causing knock? the car lost some power too.
            lose valvetrain will knock yes (ever hear a solid cam, solds like a bunch of collapsed lifters)
              Is it blowing smoke or anything? How did it happen or when did it happen? If its cold and yur revvin it you done did some mean shit to yur car!
                not blowing anysmoke, it does sound like i fell victim to the comp R lifter curse
