02 sensor question
  • 02 sensor question
    I'm installing headers on my girlfriends 99 Z28 and screwed up the passenger side pre-cat 02 sensor while removing it from y-pipe. Can the post-cat 02 sensors be used in pre-cat positions? I'm installing an off-road y-pipe so will be using 02 sims in the post-cat areas.
    Thanks in advance....
    '99 HO Z28 A4 11.60 @ 117
    Its possible.. check to see if theyre the same amount of wires or even try checkin out autozone to see if theyre the same part #.
      yes
      many use the downstream 02's from vette's too cause they have long enough wires you don't need extensions
        yes
        And supposedly they have hotter heaters in them too.
