another problem...
  • another problem...
    Hola mi amigos
    anyways
    Ok ever since I took my car into get fixed they screwed something up..my car likes to stall..
    I be driving normal..then when I put it in reverse to back into my spot at work it likes to die..and just last night it wouldnt start for me so I had to use my moms car to get home..but it always dies on me when I put it inreverse
    wtf is up!
    Wow I havent heard of that problem before unless they somehow screwed your idle rpms up and the car isnt idling right.where fixed it so I dont take my car there
      maybe its an IAC or something of that nature?
        Could be a vacuum leak. What did you have them do to it? Check to make sure that they didn't inadvertantly knock off a vacuum hose.
          well the thing with vacuum leaks is that they make the car idle up... what did they fix... that would help a lot
            Um..from what I can remember..something to do with my oil because I had a leak..I think they put on some new belts because my car was smoking like crazy..I'll be able to tell you on sunday because I have the papers back at my apartment..and I'm at my mom's house right now so if you guys can wait till sunday that will be great
              ok..got the receipt...
              2 studs
              1 oil pan gasket (looks like gasket at least..bad hand writing)
              1 oil pan
              and thats what they did
