I seemed to have developed a vibration at high speeds. The car is smooth up to about 85/90; after that, I can feel a noticeable vibration. It gets worse the faster she goes. It seems to be coming through the clutch pedal more than anything. If I press the clutch in, the vibration stops and it's smooth as glass, the second I let the pedal back out, the vibration is back. What does this sound like?
Things worth mentioning:
Stock rear-end
Aftermarket LCA's with no relo bracket
Lowered about 2" via Eibach sportline PRO springs, KYB AGX shocks/struts all the way around
stock panhard
Stock driveshaft
stock clutch I'm assuming
Stock rear-end
stock panhard
Stock driveshaft
