3.73 gear swap
  • 3.73 gear swap
    Another member on here is selling 3.73 gears, which is what I want. Besides that set, do I just need a install kit? And any suggestions on which install kit? I see some for 20 bucks and some for 200 bucks. I know you get what you pay for, but maybe something you've had good luck with?
    99 Trans am
    - SLP Air Take (LID)
    - Ported and Polished Throttle Body
    - LS6 Intake Manifold
    - 1 3/4 Long Tube Headers
    - 3" Y-Pipe
    - 3" Magnaflow Catback
    - Lower Control Arms
    Soon
    - Heads/Cam
    - 3600 or 4000 Stall
    - 3.73 Gears
    find out if they're the thick or thin gears. thick replace a 2.74 gear without changing the carrier. thin work with a 3.23 or 3.42 carrier
    When in doubt, Whip it out !
      He also had 3.23s, so thin which is what I have... Any differences in kits? don't go cheap? not sure
      99 Trans am
      - 3" Y-Pipe
      Soon
      - Heads/Cam
      - 3.73 Gears
        I used AAM gears. was told they were a little bit quieter than the aftermarket gears. Haven't had any problems 5 years and 12000 miles later. Mine was set up by DTS with a new Tru-track to replace my factory 2.73 stuff.
