need some help, I believe I need the crank relearn done. I can't move the car as it does not start, and will be hard to tow with no brakes. so you would have to come to me, sorry.
need some help from a tech2 owner
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Lowell, MI
- Meat Processor
The car has to be running to do a Crank (CASE) relearn. Your issue is elsewhere.
ok guys thanks for the info, I guess I should have researched it a bit more, back to the drawing board....guess I should ask...did the 24x conv but the car has no spark or fuel, it will crank just not start lol I got one of them small ebay oscilloscope so I can test the square wave off the crank sensor, just need to figure out how it works2002 v6 to v8 conv.
Post Slut
- 5919
- Michael H
- Lowell, MI
- Meat Processor
You have a 2002 Camaro, correct? I'm going off your vehicle info.
When I hear 24x swap I think of SBC gen 1 & 2.
Was this a v6 to v8 LS swap?
Post Slut
- 5919
- Michael H
- Lowell, MI
- Meat Processor
What are the issues? No spark, no injector pulse, DTC codes?
yes both starter turns over motor but no spark and no fuel inj pulse, I have 12v at injectors and the fuel pump will put 60lbs on the rail mounted gauge. and cant check DTC's damn snapon scanner says no communication (it only goes up to 99' but should still read genric codes)2002 v6 to v8 conv.
