Got it back together, no crank
  • Got it back together, no crank
    So I tried firing the Camaro up today. I can hear the fuel pump prime, and there is a loud "click," which I believe is the starter, but no crank. I know that there's any one of a thousand things that can be wrong the first time you try to start it once it's back together, but I have no idea where to start. Thoughts?
    Originally posted by JasonH
    battery have enough juice?
      Grounds on? Wires tight on starter? Check shoebox and verify writing on starter is right
        Sounds like a grounding issue.
          Turned out to be a bad starter
            I was gonna say tap the starter with a hammer, The ancient hill billy testing method
            Go BIG or go HOME!
