Hey everyone, i need some guidance....a couple of days ago i replaced all my plugs and wires on my 95 lt1. In order to get the old wire off on the rear passenger side i had to remove my oil dipstick tube. Ever since then i have had a oil leak there. the more RPM's i turn, the more oil splashes out of the hole. Can someone please tell me if there is a certain way or orientation the dipstick tube goes in to prevent this or am i missing something? I have the tube inserted into the block up to the metal ring or neck on the end of the tube. Help please!
Problem with oil dipstick on 95 LT1
is it seated to the sleeve and bolted in place?-Joel
It's seated to the sleeve but i dont have it bolted...actually never came with a bolt so i need to find one....any idea what size it is by chance?Originally posted by JoeliusZ28 View Postis it seated to the sleeve and bolted in place?Thanks,
Stephen
1997 Z28 LT1 - A4 30th Anniversary
Not a clue sorry man ... and that bolt is such a PITA to get started im not taking mine out to look
Lol....I wouldn't either buddy. I'm gonna remove the starter tomorrow and see if I can get it in correctly.Originally posted by JoeliusZ28 View PostNot a clue sorry man ... and that bolt is such a PITA to get started im not taking mine out to look
Thanks,
Stephen
Well, took the starter off and done it right. Cleaned the oil dipstick tube with brake parts cleaner as well as around the hole in the block where the tube goes in. Put a nice coat of Red RTV high temp on the tube, had my wife steady the top of the tube while I was underneath and gently guided it into the block. Bolted her up correctly and let her setup. That was around 3PM EST yesterday so I'm figuring around noon today the RTV should be setup....Hopefully. If all went as planned this should fix my little oil leak at the dipstick tube.... Thanks everyone!Thanks,
Stephen
Well everyone, after all the trouble i went through yesterday to stop oil from splashing out of my oil dipstick tube, i am back. The first trip down the road 4 miles and i began smelling burnt oil again. Pulled over and looked under the car and oil was dripping from my crossover pipe on the exhaust. I have done everything i can think of to seal this up but it is not working....i let the RED Permatex (RTV) set for almost 24 hours and it still didnt hold. What else can i possibly do to correct this? I have cleaned the dipstick tube with brake parts cleaner as well as the block where it goes in. Applied RED RTV to the dipstick tube and bolted it to the block....What am i missing? Will JB Weld fix this? Please, any help is appreciated.....Thanks!Originally posted by Steves94Z28 View PostWell, took the starter off and done it right. Cleaned the oil dipstick tube with brake parts cleaner as well as around the hole in the block where the tube goes in. Put a nice coat of Red RTV high temp on the tube, had my wife steady the top of the tube while I was underneath and gently guided it into the block. Bolted her up correctly and let her setup. That was around 3PM EST yesterday so I'm figuring around noon today the RTV should be setup....Hopefully. If all went as planned this should fix my little oil leak at the dipstick tube.... Thanks everyone!Thanks,
Stephen
Post Slut
- December 9th, 2011
- 5919
- Michael H
- Greenville, MI
- Die Maker
I'd try a new tube before JB Weld
Exactly what i was going to say although this seems like an unusual problem...Originally posted by hoogiesngrinderz View PostI'd try a new tube before JB Weld-Joel
