just bought my second trans am incredible deal
  • just bought my second trans am incredible deal
    Just bought a new trans am. Its a 98 a4 white with 10,000 miles on it and I got it for 8,000 I couldn't be happier the only sad part is having to sell my old red 98. Ill have done pictures up tomorrow but I also have a couple quick questions the car has been sitting for a while and needs a new battery tires and an oil change is there anything what I should replace to get her back in the groove after sitting for a couple of years?
    Change all fluids and maybe new belts.
    Seems fishy....
    2002 Z28 Camaro A4
    1993 Z28 Camaro M6- SOLD
    1999 Z28 Camaro M6- SOLD
    2008 Ford Fusion SE - DD
      Congradulations.....nice score.
      Thanks,
      Stephen
      1997 Z28 LT1 - A4 30th Anniversary
        10k or 100k?
        WE NEED PICS!!!
        congrats
          You can safely assume that all the suspension bushings are junk
            If it sat for 2 years, I'd definitely get the gas out of it and replace with new.
            Then change the coolant to Prestone All Make All Model , check the hoses, belts, rubbers, replace the fuel filter.
            Keep an eye out for coolant leaks...
              Bascially check over everything as you normally would buying a used car...
                Have someone run a carfax to make sure that those miles are correct
                1996 Base Model
                +2 cylinder mod
