98 throttle Blade
  • 98 throttle Blade
    How do I adjust it?
    You have to bend the tab. but this causes issues if the tps voltage goes to high the pcm wont see idle. When bending the tab you usually have to remove the tps and slot the holes so you can adjust the voltage as well. What are your IAC counts at hot idle? Another way is to drill a hole in the blade
      Not too sure on iac count. The only reason I'm adjusting it because of my car stalling when putting it in 1st.
