Originally posted by Dummybait
View Post
What clutch are you guys running?
Wow thats impressive! my buddys stock clutch was barely holding bolt on power at 40k miles.-Joel
LS7 clutch is on sale for 265 at Summit:
http://www.summitracing.com/parts/na...FYSf4AodgUQA7g
Even a Perfection LS7 clutch is more than $100 more then that.
I need to pull the trigger on something.1998 Chevrolet Camaro Z28 - 6 Speed
you'll need the LS7 flywheel too. I ended up getting my PP, Clutch, and flywheel through gm directly (employees can) for $417 out the door.Originally posted by nascarnate326 View PostLS7 clutch is on sale for 265 at Summit:
Rockin' the stocker as well! And yup, it's starting to slip with the new sticky rubber out back. 'Bout time for an upgrade. Never heard a bad thing about Comp clutches. Anyone want to install a slick clutch/flywheel setup in her?Pacesetter LT's, Pacesetter ORY, full MSD ign., 2 step, rear LCA's, SFC's, B&M Ripper, poly motor mounts, Nitto NT05R's, WS6 wheels, KYB AGX adj. suspension, Eibach Sprotline springs, Trickflow elbow w/K&N, All HVAC deleted w/ delete panel, no AIR, No EGR
96 Z28 Camaro M6
2008 Silverado quad cab LTZ
IIRC, GM Parts Direct had the package (shipped) for a price very similar to what I got. I think it was within $10-$15 of the $417 I paid.Originally posted by SOPES View PostI guess I will have to see how much I can get it for through the dealer...
Looks like I can get it for 375 by using an LS2 flywheel from Autozone.Originally posted by Atrus View Postyou'll need the LS7 flywheel too. I ended up getting my PP, Clutch, and flywheel through gm directly (employees can) for $417 out the door.
Why dont these come with throw out bearings?1998 Chevrolet Camaro Z28 - 6 Speed
Why would they? Throwout bearing comes on the slave, which you should replace anyway. Look for a 20% off code from Autozone and order the master and slave through them (online). Just make sure the slave has the "AP" branding on it. If it doesn't, go exchange it for one in the store like I did.Originally posted by nascarnate326 View PostLooks like I can get it for 375 by using an LS2 flywheel from Autozone.
