I have the socket mod on my PCM, and was wondering if anyone had the individual image files (64k) for the chips? I've tried to get ahold of Andrew Mattei over at AKM but it seems all his emails are dead.
Thanks!
1995 Trans Am Firebird. LT1 with 6 Speed manual. cc503 Cam. Pacesetter long tubes with true dual exhaust. LPE CAI. K&N. 4.10 Gears. ZR1 Replica Rims. Comp Cams 1.6 Roller Rockers. Double roller timing chain. BMR Sub Frame connectors. LT4 Knock Mod. Madz28 tune. Pro 5.0 shifter. LS1 Driveshaft. MSD Coil. Sequential Taillights. Custom Interior. Lead foot. CarDomain
Time Slip: 1/4 -- 12.49 @ 116 MPH
Secondly - are the image files different with the socket mod than a regular tune? Because normally a tune is 128k..
Yeah, the tune is 128k, which is split between the two 64k chips. I had an error programming the tune, so my pcm is toast until I reprogram the chips. You can actually use an intel pro/100 card to program the chips individually without needing an expensive eprom programmer (http://sandeen.net/fwfix/index.html). My only problem is I don't have the image files for the individual chips, just the combined 128k file, which from what I've read around isn't split perfectly, but rather scattered bits here and there go to each chip.
Ah bummer - I've got a 95 PCM, is it something that I could easily pull from my PCM?
Only if you have it socketed pcm, and even then it's not terribly easy and you have to have the intel pro/100 card. Here's to hoping someone can chime in with a way to contact Andrew!
