Camaro has created a tick :(
  • Camaro has created a tick :(
    I know its not the greatest quality video..couldnt figure out how to change it back..think it recorded on the lowest quality possible..but here is my new dilemma.
    Pull the valve covers off and check the rockers. Thats not a sound I've heard before tho....
      wow... that is odd.... I second the valve cover pulling, It soulds like a loose rocker arm. It may be time to get out the doctors stethoscope !!
      Go BIG or go HOME!
        Huh.
        Ive got nothing.
          turn the a/c off
            AC wasn't on at time.
              Check your idler pulley, when my bearings went out it made a similar sound..
                How would I check the pulley?
                  take the belts off and start the car
                  if the noise goes away add the a/c belt and try again - if it comes back it's one of the idlers, if not put the main belt on and see
                  I just repacked mine and they are still making noise
                  2000 Formula
                  fixed slow junk
                    before removing belts look at the a/c compressor with it off. the front part(magnet) wont spin unless a/c is off. start car and see if its spinning. The noise sounds like a blown compressor which everything may be locked up.
                      Ya I second removing the belts and checking the idler pulley / ac pulley
                      (Sold)
                      00 Camaro SS A4 T-tops (Sold)
                      99 C5 Corvette M6
                      (Sold)
                      98 Camaro Z28 A4 Coupe
                      (Sold)
                      98 Camaro Z28 A4 T-tops
                      (Sold)
                      96 Cummins 4x4 36lbs boost
                      (Sold)
                        Get a long screw driver and put it on the idler pulley bolt and listen to it. Then pull the belts
                        Go BIG or go HOME!
                          sounds like a bearing on one of the accesory brackets.
                          00 Tahoe Z71........Stock
                            As the months get warmer, going to be re-address this problem since I did not do anything about it.
                            Plan on taking belts off and spinning each pulley. Then I will work my way to the rockers.
                            Sent from my C811 4G using Tapatalk
