I picked up some supplies today for changing my rear differential oil in my 95 Z. it has just your run of the mill stock 10-bolt rear end. After doing some research, I discovered that most said that SAE 75W-90 Mobil 1 Synthetic Gear Lube was a good choice of fluid. However, it was unclear whether or not a GM limited slip additive needed to be used as well.
so my question to you guys is should I use it or not? I'm hoping someone has some experience with doing this and any tips would be much appreciated!
Thanks in advance!
Thanks in advance!
