brake rotor suggestions
  • brake rotor suggestions
    I dont have a ton of money. I ws looking at the full rotor/pad kits on ebay for under $200 but I dont want to buy junk either. I also looked at doing brembo blanks. What are your suggestions.
    2001 firehawk
    West Michigan Firebird Club
    www.wmfirebird.com
    Generally anything by AC Delco, or Hawk is pretty good.
    I have seen the ones on eBay too but an too scared to buy something that looks cool but could perform like crap.
    As for the brembo blanks, do you have the stock calipers?
      yes
      www.wmfirebird.com
        I bought the Brakemotive brakes off eBay and am very satisfied with them
        2015 Silverado
          I have brand new, stock, rear blanks sitting in the garage. I would cut you a deal if interested..
            Originally posted by JasonH
              I'll be ordering the brakemotives in the next couple of days as well.
                raybestos blanks here and theyve been great. No warping or anything and they have been road raced too.
                  Centric Blanks...They are $50 each, highway robbery. They've lasted me over 5 years but I just changed them this week. They use the same rotor for the performance version which is called the power slot and those are $100 each.
                  $80 for hawk ceramics, and you're in for $180. Spend more on good pads than rotors. Don't install the chatter plates mine were causing grinding on the top of the rotor.
                  Rears have different part numbers but here's the fronts.
                  http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
                  ~Phil
                    Check WS6store.com, they have some cheap 4 rotor packages.
                      I ended up ordering the brakemotive rotors and hawk hps pads. thanks for all the help guys
                      total cost was only like $275
                      Got the rotors on ebay for $135 and the hawk pads for front and back on amazon for about $140
                      www.wmfirebird.com
