LQ4 pcv set up?
  • LQ4 pcv set up?
    Okay. Need some help with pcv hose routing on my LQ4. Using truck valve covers and an LS6 intake. If anyone has pictures or could describe which hoses go where that would be great. Also are most people running catch can set ups and where inline are people putting them?
    2015 Silverado
      How is the PCV valve attached? Just stuck in some hose or?
      2015 Silverado
        trucks normally dont have a pcv. its a restrictor in the drivers valve conver. you can pull it out and put one there though
          So if I didn't pull the restrictor I could just follow the above diagram ignoring the pcv valve?
          2015 Silverado
            i had a restrictor in mine forever. when phil found out he told me to put the pcv back in. that back pass port also probably isnt there. The cars had the pcv right at the front with a wire bracket they held them to the coolant tubes
              i dont run a pcv in mine.. i have both ports coming off the valve covers running right to the the catch can and thats it
