Need to find a Shop in the Metro area FAST!
  • Need to find a Shop in the Metro area FAST!
    So I have been having severe ignition issues for the past two years and after exhausting all of my knowledge and capability, I need to find a shop in the Detroit Metro area that Specializes in F-Bodies and LT1 engines. I have replaced literally EVERY part associated with the ignition system, charging system, and anything to do with electrical. Anyone with a suggestion would be greatly appreciated. I want to drive my baby again!!!
    What are the symptoms?
      Random engine shut off due to a DTC 16 code. however, we have a brand new Delphi opti, jumper harness, pcm, icm, coil, wires, plugs, battery, battery cables (pos and neg) and its still not staying running.
        What do you mean by jumper harness?
          I assume the jumper harness he's refering to is the harness that plugs into the opti and then plugs into the engine harness up by the intake manifold. its about 8" long.
          If you have a bad grd you will measure low voltage pulse. there is one grd that connects to ignition coil. there are also grds that connect through the pcm.
            For reference (looks like B posted this on LS1tech back in '09 )
