Repair shops in the downriver area?
  • Repair shops in the downriver area?
    Im having a misfire problem and i cant figure it out so i need to take it in. I was ganna take it to Sean at Collins Auto but its a far drive from here and im getting terible gas milage right now. Does anybody know of any good shops in the downriver area? I wanna be able to trust them to fix my car and take it out for a lil joy ride or anything and take car of it.
    Thanks for any help!
    Dan
    98 z28, full bolt ons, and cammed
    Do you have LT's? And has the car been tunned since the cam install?
      Yeah its got long tubes, and it was tuned but when i bought the car the guages didnt work and the pcm had to be replaced to fix it, so, no more tune.
        That my friend is your problem. The misfire codes are due to the cam. See if you can find someone w/ tunning software to help you out. Mike
          I know that but it ran fine for like 2 weeks when i first got it and now it throwing a high voltage code for bank 2 senser 1. So its just dumping in fuel. Do you think a tune will fix it ?
            I highly recommend Mike K's on Ford Avenue/Northline an like 14th Street in Wyandotte. My family has been using Mike for years and years. If you go talk to Kevin or Mike and tell them Bob Daniels sent you.
              Yes the tune should fix that problem. Your O2 could be bad, but I wouldn't replace it until it's tunned since your only bandaiding the problem. Just my .02
                Both o2's are brand new and are good. Im taking the car in today to see what it is.
                  You can't be sure if they're good. I've seen brand new O2's take a dump in like 15 minutes
                    The problem is bank 2 senser 1 so i switched them around and still same side is acting up.
                      The codes will take 3 or 4 driving cycles to remove itself after you swap them.
