Its finally getting to that time everyone. I am seriously researching cams for my car. Got the Mrs on board, will soon have a garage of my own to do work and financially stable.
For those that dont know my cars current status:
1996 Z28 with stock LT1
174,000 miles
Non original T56
Newer stock replacement clutch rated for 450HP
Stainless LT headers, ORY, Hooker Exhaust
No cats, egr, or air pump
Tuned by ion.
Stock 10 bolt that got rebuilt at 140k.
Iron Driveshaft
17" ten spokes with new tires
Eibach Pro Kit with new shocks
While it has high miles the car is pretty darn clean if I do say so for its age/miles. The current plan is to do this swap this fall/winter after we get all the house stuff done.
For as much as I have wanted a 5.3 in the past, I realize its just not the smart road to take given my cars current config.
For as much as I have wanted a hotcam in the past, I realize its just not going to be a long term package.
Goals: I hate this question/term. I know someones going to ask so Ill lay it down now. I want a fun, fast, reliable, cheap, car that gets decent gas mileage and can go anywhere. Pretty sure I am not going to get all of those, but thats what I would like. Car never sees a track. I want a bad ass idle more than anything else. Second would be a car that pulls well down low and is not something that I have to rev to the moon to get moving, I love the "hunker down and go" that my car currently has when I punch it from 2500 rpm. Also tired of being so much slower than Joel, Scott, Kolin, Fred, Brian...ya everyone basically. lol
These are the three I am looking at right now.
Ai 226 / 234 - .566" / .566" - 110 LSA
Ai 230 / 238 - .566" / .566" - 110 LSA
Lloyd Elliott 226/232 .578/.574 110 LSA. – 1900-6200 RPM
Give me your thoughts, opinions, stories, bs, whatever. I dont really know what the big difference would be between all of these packages. I have talked to Ai and Elliot and both said that an "off the shelf" cam would be fine for me and recommended the above choices.
174,000 miles
Non original T56
Tuned by ion.
Iron Driveshaft
- Easily our most popular daily drivable grind for 350cid applications. Typically makes peak power at 6000-6200rpm in stock LT1 long blocks. Properly tuned it will run and drive well in M6 cars w/ stock gearing. A4 cars should run a 3.42+ rear end gear & 2400 rpm converter minimum. Can pass emissions in some states on 110° LSA, though 112-114° LSA makes it more likely to pa
- An excellent choice for 3.73-4.10 geared M6 cars. Typically makes peak power at 6200-6400rpm in stock LT1 long blocks. A4 cars need 3.73 gearing & a minimum 3400 rpm converter.
NON-EMISSIONS version of 223/230 cam mentioned above. Mild to choppy idle.
Good HP/TQ through out and a very usable power band. Best choice for “most people”
using stock bottom end. Minimum 2800 stall and 3.42 gears for B body. Comparable to
Comp 467 XFI cam.
Comp 467 XFI cam.
