Update: I put a new ECT sensor in the water pump, and it didn't change anything. So I put my spare ICM in with new coat of dielectric grease, and again didnt change anything. still firing then dying instantly if it fires at all. I am lost now... Everything seems to be intact. When I drove it home that day, it started running horrible before it died, spitting and sputtering and backfiring like crazy then it finally just died.
Dangers of driving with no belt?!?
96 Z28 Camaro M6
2008 Silverado quad cab LTZ
Obsessed
- January 13th, 2006
- 593
- C
- It's a big pretty white plane, with wheelz, curtains in the windows and it looks like a big tylenol
- MI
- Engineer
How did you fix the wiring harness pigtail going to the ECT sensor? Did you solder the wires and coat with liquid electrical tape, or waterproof heat shrink?Originally posted by Sic96 View PostUpdate: I put a new ECT sensor in the water pump, and it didn't change anything. So I put my spare ICM in with new coat of dielectric grease, and again didnt change anything. still firing then dying instantly if it fires at all. I am lost now... Everything seems to be intact. When I drove it home that day, it started running horrible before it died, spitting and sputtering and backfiring like crazy then it finally just died.
Did you pull any of the PCM codes to see if it has anything stored? Monitor the sensors while the car is running with a scantool? See if the PCM is responsive at all?
Monitor the ECT sensor feedback going to the PCM to see if the wiring harness is damaged elsewhere by the belt flying about. the wires may look ok, but be stretched/broken internally elsewhere.
Try re-setting the PCM after you repair all electrical items that were boogered up.
Well it didnt cut through the wires, so I just taped them back up. I haven't ran a scanner on it, and can't monitor it while running because the car simply wont run. If it does start, it dies within a second if that. Idk, i'll figure it out, just have to use some science and start ruling out possibilities until I narrow it down to one.Originally posted by TrickyTransAm View PostHow did you fix the wiring harness pigtail going to the ECT sensor? Did you solder the wires and coat with liquid electrical tape, or waterproof heat shrink?
Try re-setting the PCM after you repair all electrical items that were boogered up.Pacesetter LT's, Pacesetter ORY, full MSD ign., 2 step, rear LCA's, SFC's, B&M Ripper, poly motor mounts, Nitto NT05R's, WS6 wheels, KYB AGX adj. suspension, Eibach Sprotline springs, Trickflow elbow w/K&N, All HVAC deleted w/ delete panel, no AIR, No EGR
96 Z28 Camaro M6
Well in an accident you could go through the windshield
I just got off the phone with Keith from pcmforless, since he tuned this thing, and he said I most likely fried on of the drivers in the pcm. I guess this can easily happen if you run it out of power. He also said i cant just throw another 96pcm in here because the vats wouldn't allow it as well as some crank sensor issue or something. But can't I just throw a 96 pcm in there and run it?? that would at least rule out the possibility of a fried pcm. I actually have the pcm totally apart in front of me, but obviously nothing is visible. gonna put it back together, run a scanner on it, and see what it says.Pacesetter LT's, Pacesetter ORY, full MSD ign., 2 step, rear LCA's, SFC's, B&M Ripper, poly motor mounts, Nitto NT05R's, WS6 wheels, KYB AGX adj. suspension, Eibach Sprotline springs, Trickflow elbow w/K&N, All HVAC deleted w/ delete panel, no AIR, No EGR
96 Z28 Camaro M6
Originally posted by sman View PostDont know about LT1 land, but the odds of that actually happening overall SUPER slim. Everytime I see someone replace a PCM because its "bad" its ends up not being it.
I'm thinking it's the opti... I got a scan tool and tried to fire it, then it eventually threw a p0372 code, which relates to a timing reference. Upon a google search, "they" say this is usually a sign of the opti going bad. I have 93formulalt1(nick) on his way over and we're gonna put his pcm in her and give it a go (a 96 pcm as well). If that doesn't d0 anything, then it's most likely the distributor. I'm going to check it before i remove it, just need to get a volt meter or scope better yet. I'd kind of like to put a delltech system in it anyway. Screw those junk optis! Biggest flaw Chevy has ever mass produced.Pacesetter LT's, Pacesetter ORY, full MSD ign., 2 step, rear LCA's, SFC's, B&M Ripper, poly motor mounts, Nitto NT05R's, WS6 wheels, KYB AGX adj. suspension, Eibach Sprotline springs, Trickflow elbow w/K&N, All HVAC deleted w/ delete panel, no AIR, No EGR
96 Z28 Camaro M6
I guess it could be the optispark, but like my dad mentioned earlier in the thread the PCMs are extremely vulnerable when you get funky voltages going on.- Brian Meissen
well we put nicks pcm in it and it did the exact same thing. So we narrowed it down to the opti. He mentioned that you may have an opti or your dad, if that's so, I'll buy it. I'd like to try a used one first before i drop 400 on a new delco. It would need to be a vented one though. If you have one lemme know. thanksOriginally posted by meissen View PostI guess it could be the optispark, but like my dad mentioned earlier in the thread the PCMs are extremely vulnerable when you get funky voltages going on.Pacesetter LT's, Pacesetter ORY, full MSD ign., 2 step, rear LCA's, SFC's, B&M Ripper, poly motor mounts, Nitto NT05R's, WS6 wheels, KYB AGX adj. suspension, Eibach Sprotline springs, Trickflow elbow w/K&N, All HVAC deleted w/ delete panel, no AIR, No EGR
96 Z28 Camaro M6
I don't have one, but dad bought one from Ebay's "Chandler Motorsports" and it was only $90.- Brian Meissen
So, if its the opti, what's the logic here. Pure coincidence it just happened to die at the same time your belt broke? I'm not saying it isn't the opti, just thinking out loud. Its not like you were beating on it with no belt, why did this thing just randomly give up the ghost?1999 Camaro - 6 liters of fury.....
I know, I hear ya. The fact that I ran it to the point of complete power drainage, I'm thinking that may have caused the opti to fail. A couple people have mentioned that doing that could fry the opti. idk if it can or not. The only other thing is that the belt may have hit a wire that goes to the opti causing it to mess up. But i have been under this thing and checked everything a couple times over. Either way though, it's throwing a timing reference code and referring to the high-resolution signal thingy. What else could that be?!? P0372Originally posted by sman View PostSo, if its the opti, what's the logic here. Pure coincidence it just happened to die at the same time your belt broke? I'm not saying it isn't the opti, just thinking out loud. Its not like you were beating on it with no belt, why did this thing just randomly give up the ghost?
lol what?!?Originally posted by Fbomb View PostYour pants might fall down. Either way it's a clever trick if you're out for the night with a lady, er...skank.
96 Z28 Camaro M6
Vinnie's response was "driving with no belt" (around your pants)- Brian Meissen
